I have just tweaked my turbo actuator the car is now holding 1 bar of boost
Car is running a Fiesta RST engine.
The car has a T3 turbo, yellow injectors, a superchip on the ofac ecu, 3 inch exhaust,upgraded fuel pressure regulator.
It runs great and is quick, not quite as fast as my old zetec turbo., but not bad for a 1.6.
From what i have read 15psi is max boost on the stage 2 chip, can anyone confirm this?
And also would the stage one chip cause a fuel cut at 12psi?
Thanks John
Your questions have passion ford written all over them.
Are you registered on there? Its a very active and informative forum. Sure, someone will have the answer on LCB but sometimes its best to tap into
other forums as well.
Just remember to come back. This IS the best forum!!!
Are you registered on there? Its a very active and informative forum. Sure, someone will have the answer on LCB but sometimes its best to tap into other forums as well.
