Had a misfire issue with the single seater at the weekend - fairly certain ignition releated. Its a pretty standard pinto engine and the ignition
setup is a late spec (pre injection) Bosch electronic distributor using a DAB752 ignition module
I'd like to get another dizzy, even just as a spare if that's not at faukt. It seems these dizzies are a little hard to come by - would
people in the know agree with this? If so are there any OE alternatives?
The other option is something like an Accuspark ignition module. What are peoples thoughts on these? They seems a little too cheap and I'm not
sure whether I should be scared of running one in a competition car.
Any help appreciated.
I had accuspark in the original motorcraft dizzy that had vac advance locked out. ive now replaced with a new accuspark kit, dizzy ,leads coil etc. 5k plus miles without one hiccup.. spot on for price and customer service imo
123 distributor seems to work well and can be programmed
Megajolt if your allowed
what about that other ford module that looks a bit like an EDIS but has the vacume line connected ?
Thanks for info guys. Not allowed anything programmable I'm afraid so that discounts megajolt etc.
I did actually find a source of recond Bosch distributors last night so I think I'll try that first. Failing that its sounding as though
accuspark might be worth a shot. Plus they're cheap enough to be able to have a virtually full setup spare!
http://www.h-h-ignitionsolutions.co.uk/
These are the people i got my dissy from i have had no problems with it at all [ Its on a pinto ]
Jacko
This might be of interest, It is off of my Pinto / Westfield as I have fitted a Nodiz.
http://www.ebay.co.uk/itm/251298646280?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
MikeF
Jacko
Hi all,
further to my request above. Can anyone confirm what spec coil I should be using with this setup (bosch electronic dizzy). The coil in the car has a
3ohm primary resistance but the coil that has come with spare dizzy I have bought is a 1.5ohm.
I think 3ohm is correct but could do with clarification before buying getting another one!
