oil cooler plumbing advice.
bi22le - 29/7/13 at 08:25 AM
Hi all
Following my very hot bedford trackday I concluded that I do need an oil cooler for my 4age. It runs 120+ oil temp when pushed but with the additional heat and longer WOT time its was 150+. Bare in mind my temp sensor is on water to oil exchange at the oil filter under the exhaust. Well it did not go bang and doea not sound any more rattly so I guess no damage done.
Im looking at getting a mocal thermostatic take off plate and replace the water transfer but it does not have a temp sensor on it.
Can I safly stack oil filter plates? So have a plate for sensor mounting and then the mocal take off? I could drill and fit a sensor on the sump but not too keen on that as I need a quick bolt on fix before my next track day and have zero time to do it.
Anyone know of or have for sale a good place for an oil cooler kit?
Full write up of bedford track day to come.
Cheers for any advice
Bi22le
HowardB - 29/7/13 at 08:45 AM
you could fit a remote oilfilter kit, this might help, and some of them have a temp sensor fitting,...
hth
rodgling - 29/7/13 at 06:03 PM
Originally posted by bi22le
Hi all
Bi22le
Blimey, I was worried by my oil reaching 120! 150 is f*ing hot, I think you should definitely sort that. I have a couple of oil coolers for sale, I've got a brand new one 330x50x77mm, and a used one 330x50x150 mm, say £25 for either?
You could stick your temp sensor where the sump plug goes? I suspect stacking filter plates would be OK too.
Hope you enjoyed Bedford, sorry I missed you. I had a good day though, really pleased to finally have the handling of my car right (of course now the balance and feel is there I want more grip but that's another story...)
britishtrident - 29/7/13 at 06:24 PM
The sump plug is not the best place to fit a temperature sensor. You can get an inline fitting that will let fit a sensor in the hose between the exit of the cooler and oil gallery
150c is unlikely have done any harm to fully synthetic oil, but if oil in the sump is filled with semi-synthetic or mineral oil then I would advise changing the oil.
rodgling - 29/7/13 at 09:57 PM
Smaller cooler gone but larger one still available (if you're really keen on the smaller one speak to steve on here and see if he'll go for the larger one instead).
bi22le - 29/7/13 at 10:10 PM
Im using fuchs titan race R which is a ester synthetic oil. Do you think this will be ok?
britishtrident - 30/7/13 at 05:44 AM
Any full synthetic should be fine.
tommyd584s - 4/8/13 at 05:54 PM
150 is way to hot and no fully synthetic oil will not cope with this at prolonged periods of time, the heat will break the oil down and it will essentially loose it's body. I'd recommend you change the oil before your next run. You want to be reading the oil temp pre cooling as it comes out the block and try to keep it at no more than 120. 90 is the optimum but this is unrealistic. I run a laminova cooler and a 16row conventional cooler on my race car. This keeps the engine at around 120 during a 40 minute race. Hope this helps.
