ZETEC engine number ?
richyb - 17/10/04 at 08:48 PM
I am trying to identify my zetec engine (may need for SVA) i'm pretty sure uts a 1.8 130 bhp xr3i / gti. only problem is i am finding difficulty locating a date related identification. can anyone help - where are the numbers on the block (photo ?), and a source of data to enable verification thereafter.
i do have what i believe is a part number for block and head, and it has a big 1.8 on it !
any help apreciated
stevebubs - 17/10/04 at 08:57 PM
Look exhaust side of the engine where the engine meets the bellhousing - engine number is stamped on the upper edge of the flange on mine.
Ford engine info can be found here...
http://www.sylva.co.uk/engine_age.html
HTH
stevebubs - 17/10/04 at 08:58 PM
BTW, the big 1.8 means it is a 1.8 - my 2litre has 2.0 on it.
richyb - 17/10/04 at 09:05 PM
ive searched pretty well on these lines before. i think i may need to get the paint stripper out, as the guy who had it previous has put plenty on. i was hoping to get an accurate location so as to minimise paint removal. ive looked at the sylva site before, but it hasn,t helped much. i may be able to see better once shes takn back out of the car (only in temp at moment)
cheers for your help anyway
SeaBass - 17/10/04 at 09:19 PM
My 2 litre seems to have the engine number put on using more of an etching process rather than physical stamping. I'm sure in a few years down the line this will be very difficult to read. I've checked other cars of a similar age with zetecs and they are similar.
stevebubs - 17/10/04 at 09:31 PM
A picture reputedly says a thousand words...so here's a picture
http://www.cantcatchme.net/misc-images/smallZetecEngineNumber.jpg
HTH
Stephen
Ben_Copeland - 17/10/04 at 09:41 PM
picture or rather the link doesn;t work
richyb - 17/10/04 at 09:48 PM
Thanks for that - it wont take me a thousand words now to tell you that mine is covered in black hamerite !! - if its etched on, i may have to go gently with some paint stripper - i'll let you know how i get on - thanks chaps
stevebubs - 17/10/04 at 10:21 PM
Must have been a temporary glitch...works fine through google..
http://translate.google.com/translate?u=http%3A%2F%2Fwww.cantcatchme.net%2Fmisc-images%2FsmallZetecEngineNumber.jpg&langpair=de%7Cen&hl=en& ;ie=UTF-8&oe=UTF-8&prev=%2Flanguage_tools
