Once the prop is removed, can you lift the chassis up to leave the engine and gearbox (xflow), or do you have to lift the engine n box out?
[Edited on 25/8/13 by puma931]
I would say yes, as I put my engine in this way (MK Indy with MX5 1600 engine). May have to remove rad and jiggle the chassis about a bit.
Cool. I will give it a go. Thanks Mathew
Are there any cross members in the tunnel under the gearbox tail shaft ?
If you can't, try putting the rear end up on ramps as this gives a better angle to remove engine and box from the top.
HTH.
Cheers, Pewe10
There is a rear gearbox mount. Yes it will go out the bottom that's how I got my xflow.
