What to use to allow the Petrol Tank to Breath
I used one of these
Fuel Non Return Check Valve one way petrol diesel 8mm
I have just fitted one of these
http://www.demon-tweeks.co.uk/motorsport/fuel-tank-vent-valves/atl-tank-vent-valve-6-vent-inline-to-suit-6-hose-3-8-hose-barb
seems to work well
The vent should allow air in to prevent a vacuum forming as fuel is used AND allow vapour out from expansion and evaporation, but prevent the passage
of fuel out due to a roll-over or cornering forces. If you're on injection then vapour is a bigger problem than on carbs as the return line
spraying into the tank encourages it.
To do that it needs to be 2-way fuel valve and not a simple one-way valve. MerlinMotorsport sell them... Unfortunetly they're not cheap.
Is there a requirement to have any type of valve at all? can't it just be a piece of fuel pipe - suitably looped to stop it overflowing when the
tank is full?
I have never looked at a production car vent - but am sure my Vespa had a simple pipe - not least because fuel ran out of it when I dropped the bike
on it's side...
Hi
Our is same as Steve M with a filter
Tank breather & non return valve
I used this:
Took advice from the IVA techies first and they seemed to think it was fine. It passed the IVA OK so must have been
The idea is that no matter which way up the car is it should not leak fuel, yet can still vent both ways.
HTH
I used the Demon tweeks one a few posts up, passed iva this week.
I used a 2 way breather from Newton Equipment - item code RV8.
http://www.newton-equipment.com/inline_valves.html
HTH,
Matt
Originally posted by Daddylonglegs
I used this:
Took advice from the IVA techies first and they seemed to think it was fine. It passed the IVA OK so must have been![]()
HTH
I had a one way valve mounted high on the back of my race Datsun just below the trunk lid opening, rolled the car at 70 MPH no lose of fuel.
