Well managed to get out for an hour today -. I have noticed a couple of things I need to address now that I have covered 100 miles.... Weather is
not that cold but struggling to get above 65 -70 degrees... Only have the small micra ally rad so need to think about restricting cooling... Problem
is left idIng the temp soon goes up at which point I need the fan to draw for cooling... Next thing to look at s to understand if I am loosing a
bit of fuel pressure... Target iOS 3 bar but I have a pressure transducer reading about 2.8 but this drops to about 2.65 - 2.7 whilst driving... Nit
sure if this is normal....
Dave B
You need to fit a thermostat in the cooling system, also if you have a thermostat you need a by--pass connection.
Sounds like you might have a cool running thermostat or worse no thermostat?
Fuel pressure could just be dropping slightly because while your driving it's using more!
I do have a thermostat but possibly the bypass is a bit big..... I will have another check.... Idling the temp gets to 85 no problem and the fan
cuts in.... What sort of temp should I be aiming for?
I will have a check....
Thanks guys....
Dave B
Originally posted by Dave Bailey
I do have a thermostat but possibly the bypass is a bit big..... I will have another check.... Idling the temp gets to 85 no problem and the fan cuts in.... What sort of temp should I be aiming for?
Thanks guys....
Dave B [/quthat.
The size of by-pass won't effect that.
Normal thermostat starts to open temperature would typically be 88c. Fan cut in temperature should be about 96c and cut off temperature about 93c.
Dave Bailey - 3/11/13 at 08:37 PMThanks guys.... I think I will do a sensor and stat check next weekend...
Dave B
