Can't say I have much experience of playing with various flywheel weights, so looking for some input from the LCB massiv!
I'd imagine there's a great deal more 'engine-braking' with a lighter flywheel... and I guess it could be quite unpleasant when
just pootling around? Does anyone have any opinions on how light is too light?
Cheers!
I had 3.5kg on my old Vauxhall Corsa with an XE on throttle bodies, it revved like a bike and I honestly never saw any down-side to having it.
I'd go the lightest you can go without having to resort to a non-standard clutch.
Cheers Dave!
BECs have no flywheel. What is not to like?
I fitted the lightest available flywheel on my V8 and like others said there are no downsides only positives in a light vehicle. May be different in a
4x4 offroader if that's your thing
Cheers!
I would imagine most of the engine braking comes from the fact that the throttle boddy is closed and there is nowhere to suck air from.
Cheers!
4kg on a zetec seems to work ok from my experience. 6kg on the saab turbo engine is the lightest i could go without swapping to an ali one with steel
plate insert.
makes a fantastic difference to a nice light weight 7.
Engine braking doesnt have much do to with flywheel weight and more to do with cylinder sizes and compression. You learn this from riding V-Twin
motorbikes. My Ducati 748 (Increased to 853) doesnt have much in the way of a flywheel and it has incredible engine braking due to the large
cylinders, when I ride it around town I very rarely use any brakes at all until I need to come to a standstill or have the clutch pulled in.
The only bad side I have heard about lightened flywheels is apparently it can affect acceleration when going up a steep hill, don't ask me why I
just remember hearing it somewhere.
Whatever you do please do not risk fitting a lightened standard flywheel, but a properly manufactures steel one (or alloy with a steel insert).
A lightened standard one can kill.
For the sake of £200 do it properly.
