Anyone got any pix of type 9 g.box mounts?
I made my own engine mounts for zetec but not sure about the best way to go with g. box.
Rgds
Roger
my gearboxin the indy is supported using the standard bracket (drill the rivets in the big chunk as standard to leave the metallastic bush section)
this is then supported on 2 steel strips welded to the diagonal bottom tubes of the tunnel to make fixing flanges essentially to support the gearbox
bracket. drill and bolt through. bolt gearbox to bracket with original bolt and robert's your dads brother as they say.
will try and get a better pic soon if i'm not beaten to it
tom
Cheers tar great help.
Rgds
Roger www.shinybitz.co.uk
The standard sierra mount is VERY sloppy, the gearbox can have about 1/2" of movement. A westfield mount is only a tenner inc postage and is VERY
stiff. You have to make up your own mount but well worth getting it right
...and in position
And here is a photo of how we did ours.
HTH
Removable Gearbox Mounting
Originally posted by andyharding
Type 9 Mount
Certainly is.
Thanks for all the help guys big help.
If you need fuel tanks or other parts we do just call I 'll do you some discount!!!!
Rgds
Roger
Shinybitz
Sorry to hijack but we need to make a mount for our LT77 'box but the proper mounting rubbers (which you need 3 of) cost £15 each!
I don't suppose anyone knows what thread size they use and if something like the landrover engine mount would be compatible (and hopefully much
much cheaper).
They screw into 3 points on the back of the 'box, the middle one goes in vertically and the 2 either side at and angle. __/ style.
The landrover mount is M10.
They cost about £2.50 each.
That's more like it. Do you have dimensions for the LR item? Where's a good place to get them? I think the gearbox uses metric threads (V8
uses UNC i believe) so it could be a goer.
Mackie.
