Hi Guys,
What do people usually use for a gasket on the 2.0 blacktop instead of the rubber seals on the standard plenum?
Are the inlet spacings the same as the silvertop?
Regards,
Make my own out of a sheet of gasket paper and a smear of grease.
As above or fast dan does them as do others.
I use the 1.8 Silvertop gasket I bought in 2001, been on 3 engines now.
