Starter motor choices?
ianm67 - 14/2/14 at 03:33 PM
Hello chaps,
I have been doing a bit of research on this and other forums and I am a little confused....... I have a blacktop zetec and a T9 g'box going into a Dax Rush shortly. The engine has been fitted with a 1.8 zetec flywheel and Mondeo 1.8 clutch plate and cover. Standard T9 cast bellhousing and clutch arm and CT133 thrust bearing.
I have seen two starter motors used: LRS543 and LRS707. Which one do I use......??
Thanks in advance,
IanM
big_wasa - 14/2/14 at 04:56 PM
What ever you can get to fit, there is more than one that will do the job and you can find two of the same model number where one may fit and not the other if made buy different company's.
