Can anyone tell me how much fuel their tanks can hold??
35lts
home made tank
35l fuel tank over diff
jacko
4 litres
must keep thinking power/weight
20 litres
53L..
Plastic Fuel Tank 53 Litres - OSCULATI
Dint pay that much tho, search the marine webby's..
Just over 6 gallons... and I've squeezed 200 miles out of that.
60 litres
8.5 gallons
It's not how big it is but how you use it that matters
Approx 25l + 2l swirl pot. When the ticker pump gets loud I am down to a couple of useable litres.
Thats summat I've worked out recently. 30 litres.
Not entirely sure, what I do know is that the FIRST time I filled it (on the way to SVA about 5 years ago) it cost nearly £70 to fill it. I think I
worked it out at about 11.5 - 12 gallons. Enough for a 240 mile round trip.
Here you go as per body of text 11.82 gallons. linky to original posting
[Edited on 20/3/14 by jollygreengiant]
first one about 4.5 gallons,
second one 6.5 gallons, much better !
Mine is 6 gallons.
5.5 Gallons.
35 Litre with 2L swirl
But getting 35 Litre in is a mission so normally expect 30 Litre
Who worked out?![]()
6.5 gallons / 30 litres in mine. Range all depends on how it's driven, between 60 and 200+ miles.
Ian
[Edited on 21/3/14 by Oddified]
I've been building my own composite fuel tank for my fury - it's been a complex and drawn out process but if you fancy a bit of a read,
here it is.
I've designed it to run down the transmission tunnel (IRS, so no inconvenient prop movement). I'm also making a fully structural
transmission tunnel replacement, which will have composite prop-catchers in (Aramid) so I have full protection between prop and tank. I'm not
duly concerned - most of the wayward energy is angular if a prop shears so the catchers don't need to absorb a lot while it spins down.
12 Gallons.
I have the space and id like to be able to use it on long runs and with a 2litre turbo engine a good size tank was needed.
6.5 gallons
