I'm using a 2.0L Pinto with injection, I plan to keep the injection system, but I believe that I will need to modify the Plenum chamber to fit
it under the bonnet of my Indy.
Does anyone know where I can get the plenum chamber modified, preferably in Scotland.
Do you mean something like this?
Now that is nice, Who did it? where?
How bout this ? Its not mine but i will be doing it this way, just gotta find someone who can tig weld.
This is how
This is how it looks now, after a short test run
Isn't that a little strange place to put the airflow meter ?
Why strange? With an engine bay this small, you have to use every available bit of space. If I drop a spanner, it NEVER hits the floor!!
and if it didn't go there, you'd be looking at new hoses, etc etc and then all the associated paraphenalia.
will the induction charge not be slightly warmed by drawing the air from on the exhaust manifold?
just a thought like
tom
"will the induction charge not be slightly warmed by drawing the air from on the exhaust manifold? "
Very probably, but it will pass the SVA as it is, then I can run a 2 1/2 inch ally pipe to the nose cone and pick up cold air from there
