Just been going through some of the paperwork that I got with the car and on one of the dyno prints it says:
Advice, suspected choke stop
And
BIG ADVICE, 36 or 38 will need jetting back down once replaced.
I'm guessing latter is to do with fueling? Would it be over fueling at the moment? It does seem to pop a lot and top end feels pretty sluggish.
And
And
Venturi size, the venturis are limiting the airflow at wot and high rpm I take you are running DCOEs with 32 or 34mm Venturi's.
Venturis are relatively expensive to buy but they can be bored out or you might find somebody who wants to swap but the carb jets will also need changed.
Unless it is a race engine I would be tempted to leave well alone.
