Hi does anyone putting a st170 engine in a 7 have a build diary links to one on another forum etc ???
Thanks i could use the info
You can have a look through mine, not been updated since I sold it tho.
Might be something of use to you.
http://mymnrvortx.blogspot.co.uk/
Nice thanks few good ideas of were to start there
Coozer - did you get it set up on a rolling road? If so, where - or do you know a good RR company locally?
I can strongly recommend MacDonald Racing on Maiden Law, between Anfield Plain and Lanchester, for their rolling road expertise.
Regards
Jon
Thanks Jon
Won't be for a while yet, not even sourced my engine!
Mcdonald racing wont rr mine. duratec gsxr 1000 tb omex ecu. I took mine to motoscope in Northallerton.
Good to know there's a few options. Cheers!
We'll set it up for you :-)
Not too far to come... And we're cheap!!
www.baileyperformance.co.uk
Apologies to Mark for the thread 'hijack' !
@baileyperformance - heard good reports about you guys, but at over 4hrs to get there, it's not that close! Besides will be next year by the time
I have the IVA sorted and need an RR session
no problem kingster
anyone in yorkshire got a st170 in a 7 i could pop over to with my cammera and a tape measure
Thread now 'unhijacked' - as I now too have an ST170 engine! (well, when I pick it up that is)
So, might be picking your brains later on (and Coozer's too)
Main question I have now is what do I need to mate it to my Type9 box (ie which flywheel, clutch, bearing, cable clutch arm etc)?
I'll get on to induction later I guess.
You need a 1.8 escort zetec flywheel and a Mk1 Mondeo cover and plate, a CTT133 release bearing from a Capri.
That lot will go under a standard type 9 bellhousing and release fork. Alternatively, a ali RS2000 bellhousing works OK as well.
Cheers Steve, just the sort of info I was after (and I'm sure Mark won't mind either!)
Flywheel for reference...
NTDWM!
escort rs turbo efi i zvh zetec turbo efi flywheel with clutch @ pressure plate
Flush?
Ford Zetec billet Steel Flywheel ultra light RWD
[Edited on 23/7/14 by coozer]
Originally posted by coozer
Flush?
Just remembered, a starter motor off cvh or dohc Sierra.
thanks ladds ill get flee baying for some bits
forgot to ask these type 9,s does it matter if its long shaft or short as ive seen both advertised or is it just the right bellhousing i need
so just payed for this is this flywheel and the complete clutch i need spigot bearing ?? got a thrust bearing on order
Short shaft IMO.
And yes you need a spigot bearing, unless its a st170 which already has one fitted.
This any good?
FORD ESCORT LIGHTENED FLY WHEEL FOR GTI
Also, is the clutch for any particular Mk1 Mondeo? (found one for a 1.8 diesel and 2.0 petrol - are they the same?)
[Edited on 24/7/14 by kingster996]
Mine has a ST170 in it in Berkshire
this mondeo plate any specific model would tdci be better for torque ?????? st220 or year needed forgot all about it just treid the full zetec clutch and spent 20 mins scratching my head woundering why it don't fit
I have a flywheel and new clutch that I no longer need. £60 for both plus post.
flywheel on spring plate fine just need to no witch friction plate I need thanks anyway
Flywheel just as pic on page one
clutch spring and plate from ebay link on page one
are these the right ones ??
the splines in the centre of the friction plate have not got the right number teeth ??????
code on plate c142-3 spring code 2650 oy13043
Dunno mate, as long as the plate slides on the gearbox splines and the cover fits the flywheel it should go OK, what exactly is not fitting? Which
flywheel you got?
The hole in the centre of the friction plate is to small for the gearbox shaft and it has the wrong number of teeth ???????????
