Hi peeps need some advise please
I have replaced my clutch it had the same amount of friction plates and looked identical but when I put my cover back on the clutch pin is locking up
not sure what to try help!!! Got track day soon
Common problem
http://www.locostbuilders.co.uk/viewthread.php?tid=190917
Usually self inflicted during re-assembly
unfortunately i never found out what the self inflicted bit was. obviously something wasnt quite right
I tried numerous times over 2 days to get it right, with various combinations of clutch parts and even the old clutch back in and it still wouldnt
work!
eventually, by luck i beleive, it did work. so i just left it as i didnt fancy another 2 days of poo
good luck
Let see what this evening brings lol shouting definitely doesn't fix it!!!
Well got loads of pics but still not sorted going to see a man who know bike engines! Could someone message me how to post pics from Dropbox not been successful yet
can you be more specific about the clutch pin locking up?
Do you mean that with the cover and lever back on the arm wont pull it?
Did you definatly put the small plates in the right place?
Can you lever the top plate with a screwdriver and it feel springy or is the whole clutch locked up
When the cluch cove is bolted tight I carnt move the lever but loosen the cover of abit and feel like it has operation
I got hold of a Haynes manual today and looks like I have an extra washer behind the locking washer
You need to pull the cover tight with the clutch lever to ensure the pawls locate in the slot in the pin correctly
Well got a Haynes manual today and look like I had an extra washer behind the lock washer removed that it allowed the nut to sit on more i think, got the cover on and cable but carnt change gear so somthing still not right
Defeated! Managed to gain a cluch pedal that was great but then I couldn't select a gear so removed the clutch again put it neutral and lost the pedal lol good thing tho I can change a clutch 2 mins! But going to see what a bike shop can do
Quick update got cluch pedal but couldn't get it out of gear! Will the clutch only work if it wet? If don't get it sorted tonight it's going a garage tomorrow
Sorry it is dry and the clutch its working I think it was when I was trying to move the leaver by hand and couldn't I thought it was locking up but when I put the cable on it it had operation but not I carnt select gear now wondering if I put oil in it would be fine
How do you mean you cat select a gear?
You should be able to do that without the clutch, just rock the car back ann forward slightly?
Well I found its the selector shaft the dog drive bit has bent and locking the box up so need to sort a new one just not 100% what year my engine is its a 919 carb with 8 clutch plates not 10 I have seen a cbr600 shaft that looks similar not sure if it will fit
