I took the rocker cover off to do a quick cylinder head swap and got a nasty shock... thought I'd have to do a whole engine swap instead which is
a pest if you need the car the next day to go to work! but managed to recover the broken bit and there's no other damage so very lucky indeed.
Can you spot the issue?
[Edited on 18/8/14 by Mr Whippy]
Is that a broken cylinder head bolt sticking up between the exhaust valves there?
yip
not sure why it went and fortunately the gasket didn't blow which is amazing, never seen this happen before myself
There was a really small bit of the threaded section sticking out the block when I took the head off and it just spun out no bother so very luckly the
block is fine
8 valves are missing?
I wish![]()
have you got a photo of the fracture surfaces? i bet it's a fatigue failure due to undertightening / loss of bolt tension.
Might be being a numpty but how would under tightening cause fatigue failure?
Originally posted by Grimsdale
have you got a photo of the fracture surfaces? i bet it's a fatigue failure due to undertightening / loss of bolt tension.![]()
I wish![]()
Hi
Here's a picture of the broken bolt, quite a sharp break and it almost fits back together perfectly. Not sure why it broke though to me it looks
like it's been twisting at the time so maybe over torqued?
Yeah, that's fatigue.
The fracture surface is split into two main regions - one planar region and one angular distorted region.
On the planar region you can see circumferential rings, particularly near the outer edge. These are known as beachmarks and are generally indicative
of a fatigue crack progressing from the outer surface inwards. As the crack progresses, the effective cross sectional area of the bolt reduces to a
point where it cannot withstand the tensile load, and the remainder of the bolt fails by tensile overload.
Undertightening is not the sole cause of fatigue failure of bolts, but it is common. Other factors such as inadequate stiffness of the joint as a
whole, loss of tensile loading (head warping, gasket failure etc).
that's interesting thanks
Seconded - I find this stuff fascinating.
Very informative
