I have a sierra diff that is slightly smaller than the standard 7",it has the same fitting sizes (7"
across top but is approx half inch
smaller on the n/s case,it also does not accept the standard shafts,a front drive fiesta shaft fits?its a 3.62 open in mint condition but what's
it from anyone? Thanks phil
Mk5 RS2000 4x4???
Pictures would help a lot I think in this situation. Otherwise it's gonna be guess work
does it have a tag? I believe the 1600 Sierra's had smaller shafts but the casing was 7"
Would it be a 6.5" diff from a 1.6?
There is a rare 6 ½" diff used with the small engine Sierras
There was also a 1.3 Pinto
Pictures of diff
Smalldiff1
Smalldiff2
Are those even the same diff? they look different.
This a picture of some diffs that you can use to id them
The one on the left is a 7"
diffs
the right hand has an output for bolt ons ignore this,the difference is marked in white paint , standard on right slimmer on left..
