Chaps,
Some may be interested in this
NODIZ Ignition ECU with FULLY TERMINATED LOOM for Zetec 1.8/2.0
Sure a group buy can be arranged
Matt
Interesting solution, quick questions -
I had a MJ Jnr on a Zetec in the past and that had a TPS connector, the loom shown on the link only has Crank and Coil (+ and -ve as well obviously),
how does it sense load or does it have a MAP sensor built in?
[Edited on 5/11/14 by Ugg10]
Hi,
The loom pictured doesent have the 3 flying wires for the TPS/MAP sensor - normally it does.
Pics will be updated in due course
Sounds interesting. I was planning on injecting, but I have a perfectly good set of Weber 40's sat on a shelf gathering dust.
Do you have maps for a Zetec SE (Sigma)? Not fussed about the VCT as I'd likely be fitting aftermarket cams and disabling it.
Looks interesting!
You may want to contact ChrisW and register as a trader (apologies if you're already in the process).
Hi,
Yes we have maps for the sigma... if you were thinking about controlling the VVT properly our St170 VVt Controller also runs the SE/Sigma VVT
http://motorsport-electronics.co.uk/st170-vvt-controller.html
Matt
