duratec water flow
RickRick - 12/11/14 at 08:36 AM
Hi
Could anyone tell me which way water flows around the duratec 2.0 engine
Paul Turner - 12/11/14 at 08:58 AM
Just like it does in every engine ever made.
The water heats up and exits via the head to the top hose of the radiator. The water cools in the radiators and exits via the bottom hose and enters the engine again normally via the water pump.
Simples.
RickRick - 12/11/14 at 11:11 AM
ok thanks that's what i guessed at, but we found a restrictor in the inlet to the pump on the sports 2000 car we run, and i think restrictors normaly would be on the outlet from the head rather than inlet to the pump
davidimurray - 12/11/14 at 11:13 AM
Restrictor or thermostat?
RickRick - 12/11/14 at 12:37 PM
def a restrictor penny washer welded into 10mm of pipe hole about the size of a 5p just stuffed into a rubber hose onto the pump inlet
