Has anyone used, or know someone who used, an Alfa twincam engine & g/box (e.g. from the Spider)?
Dick, I like the idea and am in the process of hunting down a pre 1983 Alfa to use. The rear axle would be perfect as it has disc brakes and a LSD!!!
(clutch type that can be shimmed tight) If you use an alfetta from the same era sump instead of the mushroom spider one I think it would be even
better.
David.
I'm in the process of fitting a 164 V6 in my car. Making a bellhousing to fit type 9 box.
