Still finding my feet here again... didnt there used to be a CEC section on the main forum link?
Having a bit of trouble deciding on which engine to run in our MK.. I thought that i had decided on a Duratec but now im having a bit of a change of
heart. I know for definite its going to be a CEC.
Has anyone any experience or thoughts they could share for what would be a good fast engine to fit thats an easy enough install (easy gearbox mating,
etc...,) in an MK Indy R?
Current list:
Duratec
Zetec
MX5
S2000
Any others?
Good question....from a caterham point of view to reference to, not all that different really and if i was starting again i think i'd go down the
zetec route and aim for around 200bhp. I had an R400 with the same power and K-series, it had a steel crank fancy rods etc and was a blinding engine
but a little less reliable than a zetec historically. I also had an R300 with a VVC rover unit to caterham 6 speed box, another good combo.
I then went down the duratec route, with 300bhp and it was too on the edge, my mate has the engine now with 280 and we reckon with fuel pressure
monitoring, EWP for cooling after stop, and better oil cooling through laminova it will be reliable.
Zetec tuning seems to be slightly cheaper than duratec, and it a good solid engine, mate it to a type 9, maybe with a bit of Steve Perks input for a
longer first gear and 0.87 final, 3.92 diff and its a pretty good package (going on using a 7" ford diff casing, not sure what the MK uses).
If weight isnt too much of an issue, the reliable C20XE is a good engine, ok its old but it comes standard with steel crank and 200bhp is achievable
and very much proven with likes of SBD etc, just make sure you get one with a Coscast head.
I looked at the S2000 but the height could have been an issue, but its been done and you get over 220bhp as standard.
Happy hunting and enjoy the conversion.
FYI....i now have a CBR engine im sticking in, 165-168 bhp at the wheels and 400kg, it will be as quick and the 300 duratec around Croft!
The 04-06 yamaha r1 would be a cheap reliable option for bike power!
But I agree with Sam. A 200 bhp zetec not too expensive and plenty quick enough with added reliability!
I put an s2000 lump in an mnr vortx and it fit perfectly, height not a problem even with standard sump,6 speed box also send in as well as steering
and rear diff and drive shafts (modified)
If you were to buy a crash damaged.low mileage s2000 and strip it down, you will end up with a mega reliable 240bhp, 6 speed box and LSD for pretty
much free by the time you've sold the rest of the s2000 bits
Vauxhall Z20LET, nice, easy and cheap 250bhp+
As said s2000 is a tall engine.
Vauxhall fitted in mine easy
S2000.
If it fits in the car and budget I think it's the obvious choice.
I would imagine to get a zetec to 200bhp would cost more than S2000 inc box and diff?
Arent the duratec engines also tall? Ive heard that modifying the sump or fitting a dry sump is necessary for ground clearance? I think ive narrowed
it down to a zetec or a duratec. Seems to be a lot of donor cars about and people on here seem to have built quite a lot of them..
Also is a type 9 box sufficient for using with a duratec? Does it take much wirk to mate it to the duratec? I take it buying a donor car and stripping
it is a better option than just buying an engine unit separate?
Also when tuning a zetec does anyone have any figure on acceleration and bhp that would be what we would be aiming for when tuning?
Thanks again for replies!
Probably best balance of budget/hassle/power would be an st170 with bike tbs, ecu (run the vct in off/on/off mode with emerald or omex 600 or ms) plus
a hd long first type 9. Shoukd get you close to 200hp without opening up the engine.
But with the hd long first gearbox (£1k) that is probably getting close to s2000 cash so I do not envy your choice.
On the budget end have a look at the s13/14 200sx engine, loads of easy tuning mods avalible for 200hp+, rwd gearbox free.
Finally, something different if it will fit is the jag s type 3.0l v6 with manual gearbox, 240hp out of the box, and you have to love the noise and
grunt. Available pretty cheaply too. There is a westie around with one of those in it on itbs running around 300hp.
Originally posted by Calzonii
Arent the duratec engines also tall? Ive heard that modifying the sump or fitting a dry sump is necessary for ground clearance? I think ive narrowed it down to a zetec or a duratec. Seems to be a lot of donor cars about and people on here seem to have built quite a lot of them..
Also is a type 9 box sufficient for using with a duratec? Does it take much wirk to mate it to the duratec? I take it buying a donor car and stripping it is a better option than just buying an engine unit separate?
Another vote for the almost indestructible 5VY Yamaha R1.
They need no careful love, dry sumps, billet baskets or other paraphernalia. You need a baffle plate and a breather return to the sump and that's
it.
If there is a weak link, it's the gearbox with it's chocolate dogs. However, gears are cheap and plentiful and you really do have to be an
animal to trash the gearbox.
We have a zetec with 221.3bhp and 179ftlb, with room for more to come with a little extra work.mated to a mt75 (which is lighter and handles more
power than the type9, but less options on changing the internals, reverse is sync rowed and can be selected upto 25mph..). There are lots of people
and companies tune and make parts for the zetec and you can get crated ones for appx £850.
Not sure on the 0-60 times as it's not my thing really and depends on your diff, wheels, weight etc and whether your prepared to fry the clutch
each time for a few tenths, in the real world it's more about covering the ground on a run and coming out the corner and gathering pace rather
than a standing start.
[Edited on 24/12/14 by matt5964]
You'll do a full s2000 install for under £2k incl box,diff,ecu,loom etc inclusive exhaust! If you do your homework
If your after the s2000 there is one in the for sale section
]Originally posted by Calzonii
The op wanted to know about 0-60 etc so a less confrontational explanation would be in the Xmas spirit. Bar room bragging doesn't stop
their...BHP tends to raise its head more than often! Although we all want to know....
Type 9 has been used to death with Duratecs, as mentioned a few mods needed but readily available in kit and fitted form, depends how narrow the
chassis tunnel is as to what can be fitted.
It's been touched on but budget will dictate your choice, if you hav a figure we could whittle it down more
It's the clock that never lies Sam! All that matters really
Unless your a hillclimber! In which case a poor start means a poor run!
225 BAM engine out of a cupra r or Audi TT. Standard 225bhp stage 1 chip takes them up to 270. Forged internals as standard as well.
Only down side is a suitable rwd box. Anyone know any different?
The budget is about £10k Sam.. Im not sure atm... its an MK indy R that we are choosing as a chassis kit.
Ugg had discussed a 3.0l v6 jag stype engine.. What year is that Ugg? My dad used to have an S type and the engine pulled and sounded so good!
It hink the overall concensus seems to be Duratec or S2000? Ill keep you boys updated with further developments.. I take it cosworth engines are a
fortune?
Correct. A few hillclimbs you get 2 timed runs (barbon, Oliver's mount etc) and it is a big factor!
The top boys run big power, those with limited power very rarely do well, unless your paul masters.
Is that 10k all in? Or just for engine/ box/ diff arrangement. V6 might be a little heavy up front but it depends what you want to do with the car? Tyres and set-up/ decent shocks will make a hell of a difference, just depends what your after.
Vortex s2000 for sale!
Id love to say £10k just for engine/transmission! but unfortunately not!
haha.. Infact its prob gonna be about £14k all in for the whole car to
be finished.. Im a new graduate and living in bristol at my mates house whos a wualified mech eng of 3 years and we are lookin at a project we can
start for the next year+.. So prob about £7k each is the limit.. Hes just bought himself a house with a garage for this soul purpose!
What have you guys built?
The last few weeks ive been flatout on youtube and other places looking up stuff about kit car engine conversions.. Cant wait to get started!
Whats asking price for vortex dan?
Strangely enough I'm putting a Jag V6 into a Haynes Roadster, so may be able to answer some of your questions if you want. Also I tend to loiter
around Bristol a fair bit
Not sure mate. Brett jones is selling it part built in the for sale section.
But it will be a lot less then building from scratch! They are a very good chassis to and the guys at mnr are very good to deal with
