I have been reading a few of the threads about doing this conversion and how much it costs.
I am trying to ascertain if a relatively basic, reliable install could be done as follows:
Complete ST150 Engine (low miles inc alternator and single mass flywheel). £500 (flog un-needed bits and recoup some of costs).
Service kit for above. £50-£100.
Bellhousing – cable clutch. £200 RWD motorsport.
Duratec DCOE manifold. £130 Turbosport
Duratec Exhaust flange. £26 DanST.
Modify pinto exhaust manifold and refinish. £200 (guess)
Plumbing. Silicone hoses and fittings. £150 (guess)
Fabricate engine mounts. £100 (guess).
Miscellaneous. £100.
Dyno set-up. £215 (lynx AE).
My pinto has a set of twin 40s and Nodiz already and I was intending to swap these over and reset them to suit. The twin 40s aren't perfect but
they would provide a basic upgrade path for the future.
Is there anything key missing from the above?
RWD motorsport say that the stock ST150 flywheel can be used but the pivot pin for the clutch needs shimming. What is this and what is involved?
Tots up to £1600-1700 on top of which I guess I would get a few quid back for a pinto with 205 block, injection head and fast cam
[Edited on 4/1/15 by simonrh]
Low height sump.
Can re space pinto pipe onto manifold plate if you can weld very little expensce would sell 40s and buy bike carbs bigger chokes i love webbers but
will cost you quite a bit to re choke tubes and jet etc and you will probs need short sump
mine goes like f*** now so keep going you will love it
If you haven't seen my thread already have a look for some ideas. As a thought
Sump
New thermostat
Some form of water rail at the back of the head
possible relocation of coil pack and new ign leads
starter motor
belt tensioner - will depend on belt and getting rid of power steering pump.
Alternator - will it run without the ECU?
Clutch?
RS2000 clutch arm and release bearing.
Oil filter adaptor/relocation
Fuel rail or fuel Injector hole plugs
Just a few that jump to mind.
Clutch pivot pin is the peg inside the Bellhousing that the clutch arm pushes on when the clutch cable pulls the other end
There are longer pins available from GBS, there are thicker release bearings or you could go concentric hydraulic
I can't see twin 40's been big enough for a 2.0 Duratec either.
My pinto has a set of twin 40s and Nodiz already and I was intending to swap these over and reset them to suit. The twin 40s aren't perfect but they would provide a basic upgrade path for the future.
Originally posted by Fcck2000
I believe the differences are ..... alloy block.
Thanks for all the input, the basic conclusion is that it isn't a cheap swap, the engine prices are getting very affordable by there is still a lot more to spend over and above that. Obviously everyone's definition of budget varies but I wated to sanity check that setting aside a couple of grand was about ball park.
The Ford Duratec engines also have Alloy blocks. They are the same engine.
I thought they were all the same but for a few minor differences to suit the given installation?
All of them are alloy block and head?
Can't mention the difference between the Duaretc and MZR, but they have the same build manuals from Ford/mazda.
ST150/Post 08 Focus Duratecs have a slightly better flowing head - good for about +10bhp. Otherwise the duratecs are the same.
http://www.locostusa.com/forums/viewtopic.php?f=4&t=14753
This might be of interest if you are thinking about going MZR
They are the same i used a mondeo engine as it was cheaper than an st we also have a tuned 2.3 from an usa focus in the race car paul gardnier says he cannot get any more power with the high port head so i dont see the point in spending more money on the later head . Get the mondeo engine hone the bores put new rings on it maby arp bolts remember your carbs are going to be your power limiter i went for bodies and injection + dta that is were your £ go you should be able to buy and refresh for £400 get rmd bellhousing and fly wheel and you can use pinto clutch mine takes the power.
Did you ever do the conversion
I can't comment on whether the OP completed the switch, but many have, including me, if you have any specific questions?
Just that am in The process of doing it and to see what the results were I have a full DAN-st inlet with r1 carbs sitting which is what I was gonna
use with my megajolt ignition then someone bought the megajolt so was gonna run it with it’s own injectors with the carbs but have now bought throttle
body’s so that’s the way am going now full ecu and body’s also now have carbs snd inlet for sale
[Edited on 9/1/18 by Kerrsco22]
The result for me was a much lighter wallet and a much faster car. Win some, lose some!
I ended up with the ST150, CBR ITBs and Megasquirt, but it's all the little bits that add up, as per the list at the top of this thread.
Good Luck and let us know how you get on!
[Edited on 10/1/18 by tomduffield13]
Yeah all the 30-50£ all ad up lol I am gonna use an ems em70 ecu and a set of 45dcoe throttle body’s running the standard injectors I also have my donor engine a low Miles duratec in a mondeo ghia owened by a pensioner with full service here story at ford lol so got bellhousing and clutch fork to get along with dcoe inlet manafold then bolt together and get all the fettling done before rolling road and set up
I was advised by omex not to use the standard duratec injectors. I used ST170 injectors and have had no problems.
Cheers bud was looking at others I know one guy that’s using astra vxr ones as well
VXR Turbo.. that'll be me
Could be lol
