What are the differences between a 1.8 and 2l Pinto.
Block?
Cylinder Head?
Crank?
Con Rods?
Flywheel?
Camshafts?
I am guessing that the auxiliaries like cam cover, pulleys, sump, water pumps etc are all the same?
Not had any interest in my 1800 Pinto that has come out of the car so considering breaking it for parts.
200cc
I think the 1.8 is more derived from the CVH engine with the distributor at the front of the engine so may not have the same ancillaries
joking apart, I doubt the block or crank or conrods are the same
the other stuff maybe
code:
At the beginning of 1984 Ford Pinto engine displacement range switched from 1.3/1.6/2.0 to 1.6/1.8/2.0. The newly introduced 1.8 L engine used the 2.0 L crankshaft, so in order to uniform engine parts for the whole range after dropping the 1.3 L — the 1.6 L was redesigned to also take the 2.0 L crankshaft which had a 76.2 mm (3.00 in) stroke.
There are 2 x 1.8 Pinto's
The early version was built to defeat a company car tax bracket that made the 2.0L the top tax bracket
The Pinto series had capacities of 1.3, 1.6, 1.8, & 2.0L (2.3 in the USA but different block and head)
All Pinto's had the same crank
All pintos had the same block size but the block castings were different so you can't bore a smaller casting much past the over bore limits
There was an Eco 1.8 that had a different crank & stroke
You can put a 1.6 head on a 2.0l but compression ratio is to high and now the injection head is prefered as it flows better due to a better inlet port
short side turn and a slightly better port angle.
The 1.8 has some usable parts but cam, head, block are not worth anything
The first upgrade for any Pinto powered car is the 2.0L followed by the injection head
There is no point what so ever trying to make a lower capacity engine match or exceed the power of an identical sized bigger capacity engine unless
you are racing in a capacity restricted formula
There is no point what so ever trying to make a lower capacity engine match or exceed the power of an identical sized bigger capacity engine unless you are racing in a capacity restricted formula
The 1.8 (185 block) crankshaft and connecting rods are identical to the 2.0l. The 1.8 has a smaller bore at 86mm, but the stroke is the same at
76.95mm. The 1.8 crank even has 2.0 stamped on it, so do not throw it away as it's a good crank for engine builders of 2.0 litre Pintos. Also,
they have usually not been reground as most people just stick in a larger engine rather than trying to improve the 1.8.
According to Ike Flack (engine builder of great repute) the 185 block will bore to 2.0l as all the castings are the same, just with more machining out
for the 2.0l but I cannot confirm or deny this.
Thanks everyone - mine is a late - 1987 185 block - had hoped to sell as a complete unit as seems a shame to break it. If anyone wants any bits from a low mileage Pinto let me know!
