I'm nearly at the point where I've saved enough pennys to buy a "Quaife ATB differential: Sierra 7" rear (not Cosworth)"
http://www.burtonpower.com/parts-by-category/transmission-clutch-wheels/differential-lsds-atbs/quaife-atb-differential-sierra-7-rear-not-cosworth-qual
sd5.html
I currently have a 3.38 7" diff with push in shafts. I'd just like to check with the collective that the Quaife ATB unit will fit and work
with the push-in shafts as most of the photos I've seen show associated with the ATB and sierra diff all show bolt-on type shafts?
At one time you could only get them to suit push in shafts, so unless things have changed you will be fine.....i know this cos i had to have custom
driveshafts made when i fitted the Quaife, as i was using a Lobro setup.
sd5.html
Hi
yes you can run push fits with the atb unit its just the ford Viscous lsd that wont accept them - we have 5 cars here with 7 inch ford diff quaife lsd
and push fit joints and all are fine.
I am sure Austen (MK9r) will be along in a bit to expand as he has forgotten more than I ever knew on this topic
regards
Cheers guys........and the link ......that's the correct ATB unit for my diff?
sd5.html
sd5.html
link doesnt seem to work.....burton Part No QUALSD5
[Edited on 9/2/15 by richardm6994]
So if you have the bolt on shafts is there a quaife lsd that you can use
I was looking to use the plated type
Can anyone help thanks
[Edited on 9/2/15 by joni]
Quaife do bolt on stubs for their ATB
The ATB Automatic Torque Biasing is gear based there are no FRICTION plates in an ATB
I was looking to use a plated diff so what way do I go when I have bolt on shafts
Quaife bought Tran-x which do plated LSDs so quaife can now offer them albeit under their Tran-X brand.
Iirc you use the output flanges from a bolt on flange diff but they must be from a non LSD diff originally.
Thanks buddy
I have a 3.38 ford diff with push in shafts , I bought the atb from burton, I made all the tools to strip it totally down so I could powdercoat the
casing , I also wanted to change all the bearings including the pinion bearing which is prob 20years old!!!!!
You have to grind a small amount of the casing down on one side to get it in, I then took tit to a guy in Sheffield
Called Stuart who set the backlash, he was very good and helpful.
He supplies rebuilt diffs for rally design
Would it be worthwhile buying a diff from a BMW instead? They do Plate LSD on some cars,
Toyota do make a few diffs with torsen LSD.
Darren
I will have an atb available soon that's coming out of my caterham- if anyone interested?
I've never done anything with diffs before and I'd got it in my head that I'd dismantle the internals, fit the quaife unit, reassemble and jobs a goodun....however ive Just been reading up on setting the diff preloads and backlash......a lot more to this than I first thought.
Yes it was/is fitted to a 7" Sierra diff with push in shafts-- it's a standard caterham fitting-
It's only the actual. Atb that's available- not the whole diff
U2u me how much and when you think you'll be taking it out as I'm definitely interested
