Hi All !
now the car is on the road and passed it's MOT
I need to think about how to filter this lot.
they are honda cbr600 rr7 trumpets, which of course on the bike would be within an air box.
They are 75mm in diameter, 2 are joined and are very close to the other 2!
I was thinking of single socks and cutting up the side and cable tying - will they just keep on ripping if I cut ?
also the single socks are 10mm too narrow for their internal diameter, will they stretch ?
e
bay ram air sock
the top of the bonnet scoop isn't too far away so not too much height available.
any thoughts ? ( I know I should probably make an air box, but haven't got the time, so looking for the next best, ie something better than
nothing)
cheers
Filter socks are the work of the devil. Can you not fit slim sausage style filters?
screw the filters: kudos for the number of cylinders
how about a tray that meets the underside of the bonnet and then a filter on the inside of the inlet "slot"?
I would go for a blank plate and a ram air filter. Not going to be easy to drill out, but I reckon it can be done.
RAMAIR Twin Carb Bolt On Air Filters With Blank Baseplate 65mm Internal Height
Obviously you need 2.......I used one of these on my build and manged to cram it into a very small space.
ok - I hear you !
don't try for a quick and easy win..
I best get making a plate and filter it at the front of the scoop.
I see some late nights ahead!
thanks for your input.
perspex air box with a ram cone filter..
I think you need to think outside the box more. Supercharger?
