My newly refreshed 2.1 Pinto is in, I have bought and refurbished the inlet manifold and now need to fit a secondhand set of VP Keihin from a
CBR900
I want to check and clean the carbs prior to fitting to the car then rolling roaded
So what should I check, what should I clean and how?
I also have some questions on the plastic pipes (photos below) and screws on the carb bodies.
Large central plastic pipe
Smaller twin pipes between each pair of carbs.
Bottom of carb bowl
Top rear of carb bowl
