what oil is everyone using and how much does the diff require
Is this a sierra diff with the stock viscous LSD ?
[Edited on 23/6/2015 by mcerd1]
with 100mm flanges
Doesn't need lsd oil.
Just EP90 GL5 gear oil as the viscous lsd unit is sealed.
U know how much it needs
Can't honestly remember,1 litre springs to mind.
there's no drain plug though, you have to remove rear cover to drop oil.which is easier said than done if its never been off before!
There's a side level plug though?
On rear plate is level plug yeah
Kev you gone with the 5vy engine?
No mines a old carbed 5jj, with some headwork it did 164bhp on the rollers though
there torque setting for flange bolts when refitting?
We checked the Haynes manual and it mentioned that for our diff the oil level is a set distance lower than what we thought was a level plug (10mm
lower springs to mind)
Is this an error?
Ours is a 3.62 LSD from an XR4X4 if that makes any difference.
[Edited on 30/6/15 by brown_d9]
