With an individual throttle body setup, how is the fueling adjusted for cold start up etc?
Does the ECU just up the fueling or does the butterfly angle need to alter aswell?
Tony
AFAIA - The cold start fuel ratio is controlled by the ecu based on coolant temperature. Additionally some Fords use a valve that is to adjust extra
air flow, eg pintos, zetecs and Duratecs to up the idle speed. This feed can be connected to each throttle body by a small pipe. If your using MAP as
feedback then this will compensate for the extra fuel required. Some systems use this valve with PWM closed loop control to regulate the idle speed. I
believe that the latest version of MegasquirtnSpark-extra incorporates this but I haven't tried it... yet.
Colin
Thanks Colin
