I'm building a twincharged 2.3 lima using a t3/4 .63/.50 turbo blowing into a merc m62 with modified non mag clutch pulley
I supercharged a YB cosworth and had the throttle body before supercharger with a bypass butterfly from a mini cooper diverting the boost back to SC
intake on closed throttle and it worked perfectly, unlike the BOV i tried earlier in the build... Ha that was nuts!
This project will have the throttle body after all the boost makers, there will be a smallish intercooler between the turbo and charger and a large
fmic after the supercharger before throttle body. All this pipe work and air mass would have a terrible throttle response if TB was before everything
or even between the turbo and SC
So has anyone used a turbo wastegate to control boost? This setup will have a wastegate in the normal place doing its job on the turbo but there will
be another wastegate in place of a BOV/recirc valve after the SC (possibly venting to atmo for simplicity to start)
I have read quite a bit on an engineering forum where a wastegate has been modified with a very weak spring, and you find a gate with a large
diaphragm and a small valve. There needs to be a port above and below the diaphragm as most gates have, and a boost/vac ref from across the throttle
body. Hot side of TB piped above diaphragm and cold side below.
This can be tuned to close gradually according to throttle position and not snap shut like a BOV and have boost glide on nicely. It will also act like
a safety pop valve
Has anyone here heard of or tried this method of controlling a compound charged setup?
It sounds like a very simple idea? Am I wrong?
[Edited on 15/8/15 by Craigorypeck]
Just a thought, wouldn't it be better to run the turbo and supercharger in parallel and use a valve to divert the air depending on revs. I always
thought the idea of twincharging was to optimise the supercharger at low revs (using the merc style clutch pully to disengage it at higher revs) and
once the turbo is spooled up then divert the air flow through that. Iirc this is how the old lancia and the modern vag engines work, I also remeber a
cisworth being featured ib ppc a whike back. Would not running them in serial just cause a choke point with either the turbo choking the supercharger
at low speed and vice versa at high speed.
[Edited on 15/8/15 by Ugg10]
I have posted on here and done quite a bit of research on using a wastegate to control boost on the ITB.
Have a search on here for my posts.
I wanted to use it on an M62. Pulley it up to max out at max revs. On a 1.6 with a wastegate this would create a steep boost curve nice and low down
on the rev range and then flatten to a desired level of boost. This is done by fitting the correct strength spring. A waste gate can also recirc as it
has a ported exhaust and vacuum feed.
Originally posted by Ugg10
Just a thought, wouldn't it be better to run the turbo and supercharger in parallel and use a valve to divert the air depending on revs. I always thought the idea of twincharging was to optimise the supercharger at low revs (using the merc style clutch pully to disengage it at higher revs) and once the turbo is spooled up then divert the air flow through that. Iirc this is how the old lancia and the modern vag engines work, I also remeber a cisworth being featured ib ppc a whike back. Would not running them in serial just cause a choke point with either the turbo choking the supercharger at low speed and vice versa at high speed.
I wanted to use it on an M62. Pulley it up to max out at max revs. On a 1.6 with a wastegate this would create a steep boost curve nice and low down on the rev range and then flatten to a desired level of boost. This is done by fitting the correct strength spring. A waste gate can also recirc as it has a ported exhaust and vacuum feed.
I think you may struggle keeping inlet temps down by compounding the boost pressures.
Why not fit a rotrex supercharger instead.....those things are bloody amazing!!!!
