Hello chaps,
I am in the process of building a Dax Rush. Since DJ Sportscars sold the rights, parts and advice have been hard to come by. I have a Zetec with a
type 9 bolted to it. I have fitted a CT133 release bearing to the clutch arm and have fitted a Zetec 1.8 flywheel. The clutch kit that I fitted was
supposedly for a MK1 Mondeo 1.6 / 1.8 16V. I have had a bit of a mission finding a suitable clutch cable but finally discovered that the cable for a
2.8 Capri fitted. When I fitted the cable, the clutch arm was approximately half way across the opening in the bell housing. I got in the car,
depressed the pedal but it did not return. It appears that the cover may have failed...? I have attached a short video to illustrate...... So, I
appreciate that the engine and box are going to have to come out, what I want are some opinions as to what the issue is? Have I used the wrong
combination of parts or have I just been unlucky here....?
https://www.youtube.com/watch?v=meFryILdfdY
Flywheel fitted:
[Edited on 16/8/15 by ianm67]
Clutch cover fitted:
I had the same combination but ended up with clutch slip
(plate-cover-bearing still in the garage going on ebay)
Ended up getting a redrilled flywheel with HD pinto clutch kit from Retro Ford.
Had the lot balanced up - firked around with the clutch pivots - goes very well now.
Pressure plate not fowling on the large bolts is it?
I remember the Mondeo plate only needs a small amount of thrust bearing travel...
[Edited on 16/8/15 by johnemms]
This may sound a bit like teaching someone to suck eggs but ...... are you sure the clutch plate around the correct way ?
When I fitted the same set up I fitted the clutch fork in reverse by mistake. Clutch would not release. I had to separate the box and re fit correct way round. Simple mistake but worked fine when correct way around.
Ian i've had a real good look at the video you put up, that thrust bearing is a country mile away from even touching the pressure plate.
Does the input shaft actually make it to the spigot bush in the the crank ?
If you put the car in gear and give the car a shove have you got drive, i mean will the engine turn over ?
Such a lot of travel on the clutch fork makes me think the bell house or box might be the problem,is the box standard ?
Could it be a V6 type ?
Or possibly a diesel type 9? or a diesel /v6 bell housing ? I think the standard type bell housing is approx 7 inches from engine mounting face to gearbox mounting face, the diesel is approx 3/4inch longer
Thinking about it logically you should get drive, but the travel to the pressure plate with the fork and release bearing is troubling.
The bell house could be the big issue 3/4" (19mm) is a lot of travel and could be the key.
I have a 2 litre zetec with 1.8 flywheel early mondeo 220mm clutch kit with cct133 release and no issues.
I did go through a few cables until i got it absolute bang on though, i did not know so many configurations were available
I did go through a few cables until i got it absolute bang on though, i did not know so many configurations were available![]()
Ian i have a spare clutch kit in the man cave, I'll pop out in the morning and have a look maybe even take a picture.
as long as its a mk1 mondeo and 220mm thats what people use,binning the release bairing and adding the cct133 capri Mk1 1300 OHV one,some paperwork
i've seen reads 1600 OHC.
[Edited on 17/8/15 by bob]
as long as its a mk1 mondeo and 220mm thats what people use,binning the release bairing and adding the cct133 capri 1300 OHV one.
[img]
Clutch plate
[/img]
Valeo plate,flat side against flywheel.
Part number on box.
[img]
Clutch and pressure plate
[/img]
Pressure plate cover, which does look a little different to yours but i have seen differences before with different makes.
[img]
Before bolting under pressure
[/img]
Gap between pressure plate cover and flywheel before being bolted and torqued down.
Ian, all i can add is that i purchased early Mk1 mondeo 1.6/1.8 petrol clutch kits 1993 being the key year for 220mm clutches.
A lot of adverts i have seen especially on ebay often read "not early 1994 model"
I am pretty sure mine originally came from a company called Victoria spares who have an ebay shop.
I have to admit looking back at the pictures my cover does look very different.
