Greetings al LCB-ers. Having gone slightly crazy after searching for anyone who does suitably swaged ally tubes for the Zetec cooling system, am
reduced to asking here for supplier info.
Spotted KitSpares product list - "out of stock"! Who else provides such items?
The bottom end radiator / water pump pipes were from tiger on my car, they also supply pipes for rail at the top but i decided 32mm and 19mm ali pipe
was readilly available and i managed to find a local engineer to turn the ends on a lathe so the jubilee clips take hold.
Dick .... have a look in my photo archive,should be lots of pictures regarding water works.
[img]
bottom hose connection
[/img]
This was from Tiger, i cut it in half for pipe direction and had the ends turned on a lathe.
[img]
Bottom hose 32mm/19mm joints
[/img]
I think CBS do ally pipe with swaged ends.
Bob, thanks for the pics, and your suggestion.
Adithorp, thanks for the tip - CBS my next port of call!
[Edited on 18/8/15 by Dick Axtell]
B&Q aerial poles are cheap with bends, then drill a hole an add a nut to some old plier jaws to make a swageing tool.
Ash Hoses do to, look around for the discount code before you order though.
Shaun
Viper Performance and Merlin Motorsport are two suppliers I have used for this before.
Also used B&Q but copper plumbing 28mm pipe and half a solder joiner makes a good barb for holding a 32mm coolant hose. And you can get a 28x28x15 Tee for that bypass hose join.
Aa mentioned, ASH.
http://m.ebay.co.uk/itm/Alloy-hose-joiner-32mm-1-1-4-Silicon-Silicone-Hose-/130463707256?nav=SEARCH
Thanks for all the replies. LCB.co.uk - more specialist than Wikipeadia!!
