Hi All,
I'm looking to do my own intake manifold gaskets due to my intake options potentially moving away from the standard spacing. What gasket material
sheet would I need for the intake? I can't seem to find any definitive answer or where to buy just a sheet of gasket material to cut/trim to my
requirements.
I didn't think that stuff would be suitable? Most inlet gaskets I've come across are either steel with compressible grooves or have rubber
sections on...at least I thought that lol
[Edited on 26/10/15 by WallerZero]
I've made several for my Zetec from 1mm gasket paper and had no problems.
There are no water rails in there though so just needs to seal the inlets.
I always use a bit of intsan gasket as well.
Stu
Cornflake box and grease...
I have R 1 carbs on my Zetec on a DansT manifold and dont use anything except a bit of Hylomar.............
