I'm wanting to force the air through the radiator on my Jedi which sits in the side pod at a 45 degree angle to the airflow!
The car has 2 rads (1in each side pod) but I'm removing one as it's no longer a circuit racer and will just do sprints and hills so
hopefully won't run quite as hot!
Is there a good way of ducting air through the rad without disturbing the airflow through the sidepod too much? Cheers
Simply blank of the gaps around the rad or run a reducing box from the pod to the rad and another from rad to exit
