Are the ebay hone drill attachment tools good enough?
What's a good brand?
I'm planning on doing it my self. I have a variable speed drill and from my understanding the crucial thing is not to over do it and not to stop
honing half way and drag out the drill.
https://www.cromwell.co.uk/CTL2803994F?gclid=CjwKEAiAhPCyBRCtwMDS5tzT03gSJADZ8VjRKKvqDZ8bwMUfhMclAjBWAk70Hw2S4YjRiVJzk60RmxoCoNnw_wcB
I have used one similar many times, and borrowed from a chap who uses it regularly for work. Very easy to use, battery drill, squirt of WD40 or
similar and a few plunges up and down, job done. Never used one with the flat blades, not sure they would be as forgiving to use.
I have used one similar many times, and borrowed from a chap who uses it regularly for work. Very easy to use, battery drill, squirt of WD40 or similar and a few plunges up and down, job done. Never used one with the flat blades, not sure they would be as forgiving to use.
I just used the drill on slowish speed, probably 400rpm or less. And about 10-20 seconds a bore? doesn't take long.
[Edited on 30/11/15 by cliftyhanger]
Need to look for a 3" one. the bores are 76.3mm
So does that mean I need one just over 3 inches. This would be hard to find.
That's the advatange of the flat trident honing tools.
They are spring loaded and have the same pressure exerted all round the walls.
Have a look on youtube there are some useful videos on honing on there...
Flat blade ones are ok, but I like the flexihone ones as they are a bit more forgiving
its all in the technique
It's not really honing it's more deglazing you can only really get a proper hone finish with the proper gear in a machine shop
Actually putting a cross hatch on the bore walls.
That said I have heavily degraded bored with the eBay stones.
The biggest job was getting all the grit properly out of the bores, again a machine shop will hot wash the block
I did all the solvent cleaning I could then in a moment of inspiration (or madness) used a lint roller many many times until it ran clean and started
to stick to the bore walls
Then washed again
The other thing to consider is do the bores need looking at in the first place ?
Eg Have they been checked & measured ? Are the original honing marks still visible for instance ?
Are there any ridges at the top of the bores or deep scratches within the bores ?
*If* its just a case of fitting new rings they will need checking and correctly gapping....
If compression is good leave well alone
There are various factory bore sizes around the stated one, you can have undersized bored to oversized ones straight out of the factory
If you do go for e re-hone you will need new rings as the hatch hone is to bed the rings in
The critical measurement is piston skirt width and bore size
There will be a min and max clearance for this
I always understood if you take pistons out of a bore, even if re-using the rings, you should hone/glaze bust the bores to prevent excessive oil use
in future.
Never had an issue with bores, even a few with the odd imperfection.
The flexi-hone is just that, so get the next size up and all will be well.
If you are fitting new rings the bores must be glave busted, the surface finish should be a 45 degree crross-hatch with a surprisingly rough surface
texture.
The roughness of the surface is required to retain oil on the surface and enable the rings to bed-in to match the curvature of the bore exactly.
Found a cheap-ish flexhone 76mm. is 300 grit rough enough?
