i think i've stripped the flywheel bolt threads in the zetec crank.
Either the bolts I bought were a slightly different thread or slightly too long.
What thread are they meant to be, I will run a tap down them to see if they really are buggered.
What options do I have if I have fubared them? Is it new crank time?
M10 fine?
M11 x 1.0mm
http://www.nevlock-performance.co.uk/arp-flywheel-bolts-12.html
HeliCoil? not 100% sure that's expectable on the flywheel, but I don't see why not.
Bloke near me is selling complete engines with gearbox for £150. Cheaper than trying to fix a crank!
Problem is, i've done a lot of work on this engine, new bearings, gaskets, cambelt etc etc.
I wouldn't risk it change the crank you really wouldn't want a flywheel to detach its self .
Has anyone got a good condition, standard size zetec 2.0 crank???
If it's a silvertop then yes.
Crank is spot on, but breaking engine as one cylinder burns oil.
Got a head with new valve seals too. Oil pump done less than 250 miles. Cams are sold.
It's a blacktop. Are the cranks different?
How can you strip all the threads? Surely if you stripped 1 then you would not strip another. What do you mean t he bolts were too long? Just doesn't sound right? I would try a tap down them first, if works then no issue. the next option is to drill and tap larger, I defo wouldn't use helicoils as too dangerous.
Not sure. The rods and pistons are different, but might use the same crank?
Quick Google says cranks are the same.
The comment above about helicoil
Do not helicoil a flywheel
Not even one thread
Not now, not ever.
Not even one thread
Not now, not ever.
I've bitten the bullet and bought a new crate engine from kitspares.
I don't think they have a huge number of them left and think it would add more than the value of the engine to the finished car.
By the time I had got another flywheel, had it balanced, bought new cap bolts , I would have been spending a fair chunk of money anyway.
Remember and fit a new cam belt to your 'new' engine
Ford give these a 10 year limit regardless of mileage and they have been known to fail even on zero mileage engines...
You might get away without replacing it, but after all this effort and cash is it worth the risk?
[Edited on 8/2/2016 by mcerd1]
Originally posted by emwmarine
Good call. I had just put a new cambelt and pulleys on the engine I junked so I can reuse that new one. I have to take it apart to a degree to put the chopped sump on it anyway.
Are you mad. You should never reuse cambelts even if they are nearly new.
The new engine cost you almost £1000 after skimping on parts on the previous one and now you are prepared to do the same again.
Get down to your factors and get a Gates kit that suits your engine code. Once done you are sorted for 10 years.
There's locost and there's stupidity.
Buy a second hand car you get a used belt etc, his belt has only sat for a year so should be good for 10 years....
Bit harsh when the engine's never even run. I'm sure his new cambelt will be fine.
Not even one thread
Not now, not ever.
I,d look at going up a bolt size, drill and tap out, nothing unusual in doing that.
Exactly. Brand new cambelt in my newly (as others have said took me a year to get to here) refurbished then fubared engine. I would have thought that it's fine to just switch over.
Agreed - which is why I'd helicoil it and re-use the same fastener type and torque
^^^ but you still need enough 'meat' around the holes to use helicoils
While I'd be happier with them than I would be with oversized bolts in this situation - but ultimately zetec cranks are not that hard to replace
or that expensive either so a replacement crank would be my first choice
Of course!
