Hi,
I'm looking for a supplier or someone to make me a link piece for my bottom rad hoses.
Polo rad to 2.0 Silvertop
32mm OO main pipe with 16mm and 19mm OD outlets.
Can anyone help or is there a way to do it that I've missed???
Closes Ive found is these as was after similar set up. try reducers in line to drop from the 25mm
New ASH Fabrications Aluminium Dump Valve Connecting T Piece To Suit Pipe Alloy
[Edited on 23-2-16 by loggyboy]
http://www.carbuildersolutions.com/uk/black-nylon-stepped-t-piece-1915mm-1512mm
http://www.carbuildersolutions.com/uk/32mm-welded-aluminium-tee-with-15mm-outlet
the original Zetec pump outlet pipe has an additional outlet for the bypass, that reduces the number of adapters by 1,. then it would be possible to T from that?
Howard ??
My waterpump only has one large outlet....
Sorry Howard, just read that again properly !
The Mondeo/Focus rubber pipe has an outlet, I get it now.
Bugger and I bought the Tiger silicone one grrr..
yep,.. I kept mine, made plumbing in the bypass circuit very simple.
I have some 32 OD Ali pipe if you need, I bought 5m as it was least cost. I can put some sort of return on it an post it for small beer too,..
Here is one that I did earlier with a collar heat shrunk on it,...
hose_sensor
