Trying to remove the oil pressure sensor from the block to fit a t piece for mechanical pressure gauge.
Does anyone know what socket size it is to remove it
Not the thread size. Socket size
Need a deep socket as access is a mare
I'll try and have a look tomorrow as I'm looking into this for mine at the moment and I've got some double depth sockets.
I may fit the pressure gauge in the plugged hole to the left of the one with the sender in rather than use the t-piece.
I've looked in my spares, a focus blacktop one is 24mm, a mondeo blacktop one will likely be the same.
Dave
