Hi guys were is the best place to mount a aquasump system
I mean the canister part
Can you mount it any were ? Or dose it have to be low
Thanks for your help Jon
Interesting question.i mounted mine higher than the take off, and I have never been convinced it fills properly. I am just changing the sump baffle, and I plan to prime it low down first, before moving it back into place. I figure there will always be some oil left in the pipework, so it shouldn't fill with air again.... Interested to hear other views on this.
60psi will push oil up a considerable distance, it's knocking on for 140 feet for head of water pressure.
[Edited on 25/3/16 by mark chandler]
Whilst I appreciate they are under pressure, if there is air on the oil side of the piston, then the oil will be compressing that air - it will be taking up some volume that cannot be replaced with oil. Someone cleverer than I could work out the volume of the compressed air assuming worst case and no oil in the accusump.
I run mine up to full pressure, lock off then fill the engine to the correct level.
I know it's doing its job as the canister gets hot when tracking the car.
