Without dropping a handful of scrap down the spark plug hole It always mystifies me how bores could get so badly damaged.
The rings were intact, but about half the width of new ones, and the ring gap was about 5mm, but no appreciable lip at the top of the bores.
Compression was well down too - no $hit Sherlock!!
I've got another engine which I've stripped to freshen up with new bearings and rings, the aluminium silica bores seem really harsh on
rings, these were worn to half their width too!!
Scrap block1
Scrap block 2
Scrap block 3
I wonder if your air filter is working as well as it should...
Bore wash perhaps causing metal to metal contact due to running too rich?
That type of bore material is really sensitive to bore washing and small particles that get past the airfilter.
Even doing a compression testing without disconnecting the injectors has been blamed for damaging the bores.
I have never used an airfilter on my 7, and have never encounterd a score like that
steve
steve
You only have to look at the state of the air filter on your tin top after a few thousand miles to see how much dust it catches . The dust can be highly abrasive which is what causes the wear
