do i need a fuel vapour seperator as per my donor sierra, as me being the idiot i am, forgot to take it when i scrapped my sierra.
Ron doesnt mention it, nor have i heard much talk of them here, or anywhere else.
thanks again gents
No, you don't.
Im considering fitting one to my car as the return pipe from the carb is connected directly back to the pump inlet .This works fine until the car is
left for a few days and then i find that the carb and fuel lines are dry. If i start the car and then leave it with out the engine getting hot it is
fine the next time i want to use it,. However if i put the car away with a hot engine it appears to cause a vapor lock in the fuel system.
Paul.
thanks again gents
i have driven mine without the seperator, but i intend to put it in again soon cos the engine is running very rich (sooty exhaust and stalling when hot). since it ran fine in the donor, im gonna try the seperator again.
