I'm finally getting round to putting my pinto back together
I've got a crank scraper to fit (might as well) but whats the best way to seal it up ?
bottom end built :D
I've seen a few folk recommending an RTV silicon sealant - but which one is best and whats the best way to use it ?
I've used this stuff before on the the zetec blacktop - I'm assuming it would do the job...
https://www.fordpartsuk.com/shop/ford_sump_gasket_sealer_100_ml_f_1778303.htm
ot there is this stuff ?
https://www.merlinmotorsport.co.uk/p/hylomar-hylosil-100-series-silicone-sealant-85g-fl101hy-085g
I've not used a sealant before for a sump. When I rebuilt a Pinto for my Indy I used the gasket that came in the bottom end gasket set, which worked fine.
I used this around the outside of my gasket as previously used to leak. Just incase the oil got past the gasket & it worked a treat, bone dry this
time round
Pro Seal Black Silicone RTV Instant Gasket 85g
http://www.roughtrax4x4.com/black-silicone-rtv-gasket-maker.html?gclid=CPf1y962888CFUSfGwodrZoCdQ
Wurth sump sealant, get it at Halfords great stuff.
REINZOSIL 70ml VICTOR REINZ Silicone Gasket Sealer Gasket Sealing Compound Seal
Dirko
DIRKO ELRING VW AUDI SEAT SKODA ENGINE SUMP SILICONE GASKET SEALANT D176404A2
Fittings Burton's gaskets ?
If so. are you fitting the 'heavy duty' gasket set or the standard one ?
