Been painting the cam cover today used the water technique to do the black lettering, turned out well I think!
Not wishing to sound ignorant, but what is the water technique?
Thanks in advance.
Thanks in advance.
Yes that's correct, spray with primer the whole cover, then spray letter colour over the whole cover, then fill letters with water, then a white base coat or primer again, then your final colour to finish, remove the water and you have the desired finish
I used a different modus operandi with raised lettering. Spray the lot then machine the tops off the letters. Carefully, very carefully!
More photos of cam covers please.
Always learning new techniques - great work guys
[Edited on 1/1/17 by robinj66]
Nice colour choice
Mine is powder coated then hand painted.
