I have read somewhere that the best way to change the cam belt is to cut the existing belt down the centre removing half and then slip the new belt on
before cutting the remains of the old one off.
Is this the case?
The process I suppose is to put the car in gear, remove the aux belt and pully on the crank. Take it out or gear and crank the engine over by hand and
use a sharp knife to cut the belt. Then remove half slip the new belt on and cut the remaining piece of old belt.
I then push the new belt home and replace the aux belt. Before running I need to check the timing marks to ensure no slip up occurred.
Having sold the car to my son I don't want to ruin it for him.
Regards
Ditch
A way, not the best way I suspect.
prob not the best way I agree, but the cam is fitted with at vernier / adjustable pulley and I hav as yet to find top dead centre markings on it.
If I use the markings on the cam it could be advanced ahead of the crank if you get my drift and I'm nervous about getting it horribly wrong.
is there a way or tool to lock the cam pulley and prevent it moving?
regards
Ditch
I've got a similar set up. I just set the engine to tdc on the crank timing marks, marked the cam and auxiliary pulleys "12 o clock" positions, swap belts and check marks. You'd soon see if anything's one tooth out, as one tooth is quite a lot in degrees.
I wouldn't risk it, besides the chances of you getting the new belt on without releasing the tensioner aren't good
Changed Toyota recently..
Put white paint on belt and tooth..
Took off belt - copy marks to new belt..
Match new belt to tooth marks..
Worked for me
The engine was bought direct from vulcan engineering with the vernier set up correctly for the fast road cam that is in it.
I laid the car up during the recesion and since the wife won't get in it I put it up for sale. My son has bought the car and as it has been laid
up I am changing the cam belt for him. There has been lots of good advice. So I will think hard about it. Still don't know his plans for the car
as he is in the army and has nowhere to store it other than my garage.
Thanks chaps.
Ditch
Mate not a good way as while your in there you need to check adjusters or pulleys etc. It's a quick way and does work. The easy way for you is tippex. Mark teeth and put a dam to align them up you have timing marks now ;-)
Put a dab that was lol not dam
