Fuel Filler Hose
Huttojb - 20/5/17 at 02:54 PM
Hey all
I'm looking to move my Fuel Filler Cap but need some more hose to reposition. The Hose that's fitted won't bend to a new location so may need some flexible hose.
Looking on eBay it seems very expensive for a meter of hose, can I go to the local scrap yard and get some hose, what car would provide the best hose to remove. Looking for a 38mm ID Hose!
Jason.
ste - 21/5/17 at 09:54 AM
Not that expensive
https://www.carbuildersolutions.com/de/budget-flexible-fuel-fill-hose-38mm-id-x-500mm-long
Huttojb - 21/5/17 at 04:01 PM
Originally posted by ste
Not that expensive
Thanks Ste, I saw that late last night.
I've noticed that there are no filler Caps with a 38mm neck, so need to get a reducer from 51mm to 38mm.
Jason.
Huttojb - 21/5/17 at 04:04 PM
Would these reducers work for fuel??
https://www.ebay.co.uk/itm/331748770153
ste - 21/5/17 at 05:17 PM
Suitable For Use With Air And Water, But Cannot Be Used For Oil And Fuel Applications.
ste - 21/5/17 at 05:23 PM
you need fluoro lined silicone for fuel.
I may have a small length of 50mm fluoro lined hose you can have, then if you get one of these reducers
https://www.carbuildersolutions.com/de/cnc-alluminium-reducer-50mm-to-38mm
you can then use the 38mm flexi hose i showed you before.
