i already have a map for my engine on my omex
if i plug a lambda sensor onto the loom can i log the data from it with a pc, without it affecting my installed map ??
I suspect you will have to ask Omex that question. Guy seems very helpful whenever I have a question for them
reading the book it suggests that turning the oxygen feedback rate to 0 will disable it... not sure if that still allows logging
