Can exhaust be ridgid or does it need some flex component?
Engine is BMW 6 cylinder and original exhaust did not have flexis but probably had play in the rubber exhaust hangers. I'm using the landrover
engine mounts that seem stiff, will the engine move much under load?
[Edited on 26/5/17 by craigdiver]
Just use rubber bobbins to mount the exhaust to the car?
engines move quite a lot, so you need some flex somewhere.
the other problem with a rigidly mounted exhaust is conducted noise.
My BMW 6 is on Landy mounts too but I've also fitted a Mini engine steady. The exhaust has no flexi and the silencer is sat on a single poly bobbin. Too early to say if this is gonna last without an issue.
My engine is on MX5 engine mounts and the end of the exhaust is on a rubber/metal silencer fixing (can't remember what I pinched it from) it has two studs each side of the rubber and it works fine :-)
Hi Nick, your not sounding too confident ;-), if you made your exhaust again, would you have fitted flexis?
Craig
My Pinto manifold was over the rail type, 4 into 1 and was rigid to the silencer mount. The mount was a big cotton reel type. I found that the silencer developed an internal rattle that quietened as it warmed up and I suspected the rigidity of the exhaust set up. I put in a short flexy pipe between the manifold exit and silencer and was surprised at how much the engine was now moving. I think including a flexy section is a good idea.
