I have a Ford Type 9 gearbox and Sierra IRS differential and wondering about criticality of propshaft alignment and the possible consequences of
misalignment. At the moment I have about a 1.7 degrees horizontal offset which is taken up by the front coupling and about 2 degrees vertical offset
which appears to be taken up by the rear coupling. Is this within the normal range for the propshaft couplings or should I be worried about it?
I think I can reduce the vertical offset a little by raising the rear of the gear box, and I intend to do this, but cannot remove the offset
completely without having new engine mounts made. Similarly I think I can reduce the horizontal offset a little but cannot remove it without moving
the engine forward to provide more clearance with the chassis - something I'd like to avoid due to the impact on weight distribution.
If I can reduce both horizontal and vertical offsets to the 1-1.5 degree range and run at this level are there any consequences in terms of
durability, vibration, other..?
General rule of thumb is that some misalignment is actually a good thing, so the UJ's get some exercise. However, the gearbox face and diff face must be parallel in all planes.
Originally posted by Rosco
I have a Ford Type 9 gearbox and Sierra IRS differential and wondering about criticality of propshaft alignment and the possible consequences of misalignment. At the moment I have about a 1.7 degrees horizontal offset which is taken up by the front coupling and about 2 degrees vertical offset which appears to be taken up by the rear coupling. Is this within the normal range for the propshaft couplings or should I be worried about it?
I think I can reduce the vertical offset a little by raising the rear of the gear box, and I intend to do this, but cannot remove the offset completely without having new engine mounts made. Similarly I think I can reduce the horizontal offset a little but cannot remove it without moving the engine forward to provide more clearance with the chassis - something I'd like to avoid due to the impact on weight distribution.
If I can reduce both horizontal and vertical offsets to the 1-1.5 degree range and run at this level are there any consequences in terms of durability, vibration, other..?
