diff noise more in 4th?
legend - 13/6/17 at 09:25 PM
running westfield with type9 box i know the diff is noisy and needs new crown and pinion but it seams loader in 4th gear is this normal?
adithorp - 14/6/17 at 06:14 AM
Noisier at the same speed? Gear shouldn't make a difference to diff noise; Only speed or load.
Sam_68 - 14/6/17 at 06:46 AM
^^^ Broadly this.
But I suppose some sort of weird harmonic could be going on between the diff and the gearbox in 4th gear.
Dingz - 14/6/17 at 10:04 AM
The gearbox will be quieter in 4th, perhaps thats why the diff sounds noisier.
CNHSS1 - 14/6/17 at 10:17 AM
With a rigidly mounted diff it could well be a gearbox issue more noticeable or allied to 4th gear, transmitting down prop and resonating at the diff. A spaceframe chassis does make a great sound box and the tiniest rattles can ring like a bell, but not necessarily where you look. I'd check engine mounting and gearbox mounting are tight and in good order too
nick205 - 14/6/17 at 11:47 AM
Has it got more noisy over time?
When I built an MK Indy the Sierra diff was rigidly mounted just behind my bum. I could hear it, but then in a Sierra is mounted in a rubber mounted sub-frame beneath the car so it's going to be quieter.
