Having recently acquired a new car running a Pinto one of the first things I need to do is to replace all of the coolant pipes. Does anyone have a
diagram showing pipe ID's so I can order new shiny bits without having to dismantle what's there first ?
Thanks,
Ian
Need to check but top of head
Thermostat to radiator top hose is 32mm to 32mm
Bottom hose is 38mm out of pump and 32mm at the radiator
Thanks for that as a starter, has anyone got a definitive list ?
Thanks again,
Ian
